Best Affordable CO2 Monitors
For some reason, this forum post outranks my dedicated post on the best CO2 monitors. If you’re interested in learning more about the best carbon dioxide monitors in all price ranges, please refer to the article below. Thank you!
Please note: This post contains affiliate links.
When it comes to carbon dioxide monitors, there is one question I get asked more frequently than any other, and if you’ve read the title of this post, you’ll already know what it is. It is, of course, ‘What are the best affordable carbon dioxide monitors?’. While I’ve already partially answered this question in my article on the best carbon dioxide monitors, I thought discussing the topic in more detail would be great.
Before diving deeper, I want to mention that on my main website, I only discuss monitors with which I have (ample) firsthand experience. This is because I feel uncomfortable recommending any monitor I haven’t tried personally, and I also feel it’s disingenuous. However, there are a few great-looking affordable carbon dioxide monitors out there that I haven’t reviewed yet, and I want to mention them in this post as they are less formal. With that said, if you have experience with any of the monitors in this post, I welcome your thoughts and opinions - in fact, I would love to hear them! Therefore, please feel free to comment below if you have any thoughts. With that said, let’s get started!
Best very low-cost monitor (< $50)
Full review:
It probably surprises no one, but I still recommend the Vitalight Mini CO2 Detector for anyone with a very strict budget. This device is far from perfect but performs well in the most critical metric - accuracy.
The Vitalight Mini CO2 Detector can be found for $30-$50 depending on sales and your location, and the accuracy of this monitor is unmatched at this price. While I have heard some people mention that it doesn’t track well compared to their Aranet4s or other higher-end CO2 monitors, I’ve found the opposite. Across the two Vitalight Mini CO2 Detectors I have, I’ve found that they almost always record very similarly to my Aranet4 Homes and other monitors.
Of course, there are some times when they read very differently, and this is generally due to the (rather frustrating) auto-calibration ‘feature’. This ABC (automatic baseline calibration) operation is performed about every seven days, and it sees the device set a new CO2 baseline at the lowest concentrations it has been exposed to over that period.
This is often advertised as a feature because it means, in theory, that the user doesn’t need to calibrate the monitor. However, this is only the case if the device is regularly exposed to ambient CO2 concentrations, as otherwise, the device’s readings will quickly become skewed. Luckily, the device can be manually calibrated, and as long as it’s managed properly, this device is surprisingly accurate for the price!
Of course, the device does make some compromises at this price point. One of those is that the device lacks connectivity in any form. On top of this, the battery life is very short (around 8 hours), and I’ve heard from some readers that there are quality issues with the device. While I can’t confirm this, as my two devices have worked great (they are now around two years old), it seems to be a relatively common issue. However, I haven’t found any devices as accurate as this one at this price range, so I still think it’s a decent, affordable carbon dioxide monitor.
Other affordable monitors (< $50):
Other options from brands like Temtop are also available in this price range. While I haven’t tried these monitors, they appear to use accurate NDIR or photoacoustic sensors (always check for one of these in any monitor you are considering).
August 2025 update: I now reccomend the INKBIRD PTH-10C as another great and affordable CO2 monitor. Please read the comments on this thread to learn more.
Best affordable carbon dioxide monitor (< $60)
If you don’t mind spending a bit more (typically around $60), you can get a fascinating monitor that performs very well but with a few caveats. I am talking about the Sensirion CO2 Gadget. Now, the biggest downside of this affordable carbon dioxide monitor is that it isn’t an all-in-one device. That is to say, this device needs a battery to operate and it needs to be powered via a USB port. While this might seem a big inconvenience, this monitor has significant advantages over the more affordable Vitalight Mini CO2 Detector.
Firstly, this affordable carbon dioxide monitor uses a Sensirion SCD4x (an SCD40 or SCD41) sensor. This sensor is an ultra-small CO2 sensor which uses photoacoustic technology to provide accurate CO2 concentration measurements. While I do have some minor issues with this sensor (it appears to lose accuracy at higher temperatures), it tends to perform very well at standard temperatures, and it’s also incredibly tiny, meaning it can fit into very compact devices. While I do think this sensor still takes second place to high-quality NDIR sensors such as the SCD30, S8 or Sunrise, it performs well, and I would trust it in most conditions.
Secondly, this monitor supports Bluetooth, meaning you can view data on your smartphone (or PC if you use it on your computer’s USB port). This allows you to see historical data, giving this device a significant advantage over the Vitalight Mini CO2 Detector.
This is a fantastic low-cost solution if you’re looking for a great CO2 monitor for your home or office (or anywhere it can easily be powered). While it can also be used on the go, you will need to sort out a way to power the device. With that said, if you don’t mind also carrying around a battery, this is a fantastic value CO2 monitor.
Best affordable carbon dioxide monitor (< $80)
Full review:
Just a year ago, I would’ve said you needed to spend at least $150 to get a carbon dioxide monitor without major compromises. However, SmartAir and Qingping have since changed the game by making an affordable carbon dioxide monitor with no major downsides. While there are a few quirks to using this monitor, it’s a very well-rounded device, and it can be found for less than half the price of premium devices such as the Aranet4 Home, INKBIRD IAM-T1 and CO2.Click Model C.
The SmartAir CO2 monitor also uses a Sensirion SCD40 photoacoustic sensor and generally has great accuracy except for at very high temperatures (which is an issue that all photoacoustic sensors suffer from). Luckily, in the conditions this monitor will mostly be exposed to, the sensor is accurate and reads similarly to high-end NDIR sensors.
Since Qingping makes the SmartAir/Qingping CO2 monitor, it uses the same app as the Qingping Air Quality Monitor and Air Quality Monitor Lite. Since this app is quite good, I see this as a big advantage of the device, which means you have great connectivity with this monitor. With that said, there is one caveat - while the SmartAir CO2 monitor has Bluetooth and WiFi, it only uses the former to pair with your phone during the initial setup. This means the monitor will not upload data to your phone while on Bluetooth - only once you get home and it’s connected to WiFi again. This isn’t a major issue, as you can still use the device while you’re out, but you won’t be able to view data on your phone until you are home (or somewhere else with WiFi).
However, this is the only big disadvantage of this monitor. The internal battery (which has a 5-30 day battery life) has decent battery life, customisation is good through the app, and accuracy is good. Really, the only other minor gripe I have with this device is that it’s quite large.
For now, that concludes this list of affordable carbon dioxide monitors. Is there anything you would add?
I want to add a few more monitors to this list. Firstly, a couple of devices deserve a mention at the top end of ‘affordable’ (around $100).
1. The Qingping Air Monitor Lite.
Full review:
I mentioned this monitor’s sibling in the initial post, but I think it’s unfair to overlook the Qingping Air Monitor Lite as this device is also very popular. While it doesn’t have the same battery life and portability as the Qingping/Smartair CO2 monitor, this monitor also measures other pollutants - namely, PM2.5 and PM10.
While I don’t trust PM10 readings from any low-cost sensor, I appreciate the addition of a PM2.5 sensor, which makes this device more well-rounded than a CO2-only monitor. With that said, you will lose some of the strengths of Qingping’s dedicated CO2 monitor, such as its portability (this monitor only has an eight-hour battery life).
While the sensors used on these monitors can vary (depending on availability), they use CO2 sensors from SenseAir or Sensirion, trusted brands with good reputations. While the PM sensor is a bit less tried and tested (it’s from Grandway), I’ve found it accurate enough.
2. CO2.Click Model F
The CO2.Click Model F is a cheaper alternative to the much more pricey Model C. While I haven’t used this monitor yet, I love using the Model C, which shares many similarities with the more expensive device.
At $129 CAD, the Model F is a bubble-gum stick-sized CO2 monitor that uses a Sensirion SCD41. While I initially had some doubts about the sensor, those were cleared up after this discussion. I now believe it to be a great CO2 sensor.
This monitor has around 15 hours of battery life, meaning you can easily get through the day, but you must charge it every night. While this isn’t ideal, there are always trade-offs to be made at this price point, and in return, you’re getting a fantastic sensor.
If you’ve tried the CO2.Click Model F, please feel free to share your thoughts, as I would love to hear more about how the device is for daily use.
3. Other affordable monitors.
I’ve also recently come across the below monitors, but I have no idea how they perform. They both have NDIR sensors, so they should be accurate:
Hi, do you know which model has sound alert that can notify the user of abnormal CO2 readings?
Great question! I’m just speaking from the top of my head, but I believe that most of these monitors either have alarms and/or notifications (to your smartphone) when the CO2 levels reach a certain threshold. In regards to a sound alert, Vitalight supports this, and I think some of the QP monitors may, too. However, I will check on this for you!
I have been told the QP/SmartAir monitors also have audible alarms.
Thank you for the detailed breakdown of affordable carbon dioxide monitors! It’s great to see someone who values firsthand experience with the products they recommend. Your insights into the Vitalight Mini CO2 Detector are particularly helpful for those on a strict budget. It’s reassuring to know that despite some minor drawbacks like short battery life and occasional calibration issues, it still offers impressive accuracy for its price range.
I appreciate you mentioning other options like the Sensirion CO2 Gadget and the SmartAir CO2 Monitor, both offering additional features like Bluetooth connectivity and extended battery life, making them versatile choices for different needs and environments.
If anyone has experience with these monitors or other recommendations to add, I’d love to hear more opinions on which affordable CO2 monitor works best in real-world scenarios. Your contributions make navigating the choices much easier!
Also read: CEO Leadership in Carbon Accounting for Businesses
Another option at $99 (that also monitors particles) is the AirFanta G2.
You can also include HibouAir indoor CO2 monitor. I have been using it for sometime. detailed specification available here
Thank you for pointing this out! I will look into it.
I’ve recently completed my full review of the CO2 Click Model F which can be found here:
I believe this is another good (relatively) affordable option which fits into the same price bracket as the Qingping/SmartAir CO2 monitor. If you prefer a connected option, the Qingping monitor is better. However, if you are looking for a standalone but accurate monitor, the Model F is worth looking into!
After being asked about this device many times, I finally decided to pick up an INKBIRD PTH-10C. This monitor costs around $35, and I am curious to see if it can be an even cheaper alternative to the Vitalight Mini CO2 Detector.
I still need to do more tests, but so far it does at least appear to be using a genuine NDIR sensor (it reacts quickly when I breathe on it and does not react to alcohol and other VOC sources).
I’ll update this when I know more!
Great topic! I’ve had good experience with the Forensics Detectors CO2 Monitor for affordable monitoring. It uses NDIR sensor technology with 1 ppm resolution, which gives really accurate readings for the price point.
What I like most is that it comes factory-calibrated - just plug it in and you’re monitoring immediately. It’s wall plug-in powered, so no battery hassles, and tracks humidity and temperature too. The build quality feels solid and it’s been reliable for continuous monitoring in my office.
For the affordable range, I think NDIR sensors are definitely the way to go over cheaper alternatives.
I know think the INKBIRD PTH-10C deserves a place on this list. It’s a little bit more expensive than the Vitalight Mini CO2 Detector, but still very affordable at < $50. You can find my full thoughts here:
If you want the full details, please read the article. However, for a quick summary, here is why I now think this is the best (very) affordable CO2 monitor:
  1. More durable build than the Vitalight.
  2. Allows the user to turn off auto calibration (the Vitalight does not allow this).
  3. Has a far better display.
  4. Better battery life
A few other users have also confirmed the improved durability, so I am now confident to recommend this as my favourite low-cost option. If you’re interested, you can learn more here (this is an affiliate link. You can read my full disclosure here).
Have you seen the T-A37 for 30€ sold by Conrad in Germany?
It has no connectivity, but a blinking red light after 1000ppm and it goes even faster after 2000 as well as a (deactivatable) beeping alert.
It can be run indefinitely if connected to a micro USB power source and it has a battery for travel/mobile-ish use. There is an (optionally) backlit display.
Setting the clock correctly is a bit tricky but otherwise it’s fine.
Shape is ergonomic, casing colours are a bit ugly. Sensor is NDIR, it has auto and manual calibration.
I didn’t know about this - thanks for bringing it to my attention!
Do you happen to know what sensor it uses? I can’t seem to see the information (but may just be overlooking it!).
No but i can disassemble it in two weeks to take pictures, can you send me a reminder after October 5?
@vonneudeck . Sorry about this - I totally forgot! If you’re still interested/willing to, here is a reminder :slight_smile:
My travels are taking longer than expected and I don’t have the tools with me. I’ll disassemble it once I’m back home
September 2025 Amazon post on the Qingping CO2 Monitor Amazon.com: Qingping CO2 Monitor Thermometer Hygrometer, Remote Monitoring via Qingping IoT, Temperature and Humidity Monitor for Different Scenarios, Fast Alert Notification, Rechargeable Battrey : Patio, Lawn & Garden which may be the same as the SmartAir?
"I bought three of these in 2024 that work great. They interface with home assistant, they update every 5 minutes, and they are as accurate as my aranet4
I bought 2 in September of 2025 and the new ones are pure junk. They look identical but the hardware is different. It does not connect to home assistant, it doesn’t update the app, and the CO2 is completely wrong, on both units!
Do not buy. They cheapened it to try to make more profit and ruined a good thing .
The firmware version on the new ones is also different"
Very common problem with stuff on Amazon.
