Radon Monitor Reviews
October 2025 update:
Since this thread gets quite a lot of attention, I’ve created a dedicated post on this topic. You can find it here:
This thread will remain as a testing/discussion thread.
I also wanted to introduce my air quality monitor comparison tool that can be used to easily compare radon monitors. You can find the tool here:
Original post:
Since starting BreatheSafeAir, I’ve often been asked if I plan to review radon monitors. Until now, I haven’t dipped my toes in the field of radon monitoring, and it’s been interesting to me for a while.
After receiving a few monitors around a month ago, I wanted to announce that I am now working on a range of radon monitor reviews, which I will share here once they are complete.
I’m first working on a review for the Aranet Radon Plus, followed by the RadonEye, EcoCube, and Airthings Corentium. While I’m not quite sure of the exact order in which I will review these devices yet, all four reviews should be completed within a few months (as I am also working on some other articles alongside these).
I also have the Airthings View Plus, which features a radon sensor. However, I’ve already completed a full review of that monitor from the point of view of someone looking for a comprehensive air quality monitor. I am, therefore, looking forward to trying this range of dedicated monitors.
Please let me know if there are any other radon monitors you would like to see me review! I would love to try more of these monitors and am open to suggestions. I’d also love to hear your thoughts if you’ve tried any of the monitors above.
The first of these radon monitor reviews is now live and can be found here:
If you’re interested in purchasing the device, you can find it here (affiliate link): Aranet
Please let me know if you have any thoughts!
Airthings Corentium Home review:
It would be nice if you could also review the Air-Q Radon, which seems to be the only device which is capable of measuring Radon every 2 minutes. As this is a new device, there is currently no comprehensive comparison available.
You can get the 5 sensor version from here:
The 11 sensor version is available here:
I have been looking into consumer grade radon monitors as radon is prevalent in my area. I have had radon mitigation done years ago, but I would like to monitor for effectiveness and to see if alterations in my home trigger issues. Radon seems like it’s a difficult thing to monitor and there is a range of quality issues on the consumer side.
From what I have seen so far, the EcoSense EcoQube and RadonEye seem to be well regarded. Unfortunately, the EcoQube doesn’t integrate into Home Assistant (which I will be setting up). The RadonEye appears to have some work arounds to get it to pair, but some of the newer models may have difficulty.
The Air-Q products look pretty nice and I like that they have multiple sensors which could help correlate the conditions which cause Radon spikes so that you could remedy. They come with a heavy price tag unfortunately.
Hi @hauchig, and welcome to the forum.
It’s funny that you mention this! I’m actually working on getting an Air-Q monitor for testing at the moment. While it will take a while to get here (and a while to test the device), I will hopefully have a full review to share in the next couple of months.
I’m quite curious to test these monitors, especially the comprehensive variants, as they could be a great (albeit very expensive) option for anyone looking for a high-quality all-in-one monitor.
Also, I could be wrong, but I believe the Aranet Radon monitor has quite frequent updates. Of course, the longer-term readings are typically much more accurate and should be relied on much more than the shorter-term readings.
Where are you based? I only ask because, while I have both the EcoQube and the RadonEye, I haven’t yet been able to fully use them because the apps for both appear to only be available in a few countries (the U.S. and I’m sure a few other larger markets). Therefore, I would not recommend either of these devices (especially the EcoQube, which seems completely unusable without the app) unless you are in the U.S.
With that said, if you want something that integrates with Home Assistant, the Aranet Radon monitor is also worth looking at. While it doesn’t yet have third-party testing as it’s very new (I’ve been told they’re working on this at the moment) it has the best integration out of the monitors I’ve tried.
I am located in the US, so the app would work in my situation. You’re correct that the EcoQube would have no functionality without the app. The Radoneye would be limited as well I believe. I believe they have been promising an API for years, but it has yet to materialize.
Thanks for pointing out the Aranet Radon Monitor. I had originally dismissed it due to its newness and partially cost. However, it does look promising. I like that it includes some additional atmospheric measures to potentially help understand radon fluctuation. Fantastic that it has Home Assistant integration as well.
That’s good to hear; in that case, you have a lot of choices! Yes, the RadonEye will work without the app (the screen still shows the concentration), but other than that, it will lose all of its functionality.
I can understand your stance on the Aranet, and if you want to wait for third-party testing, that’s very understandable. That said, Aranet has a good track record, and its other devices are well-regarded, which is the only reason I think this is likely still a good device before we see some third-party lab/testing results. Its feature set (like the HA integration) also makes it very appealing, and it has, by far, the best app of the monitors I’ve tried.
Sounds like it’s probably the way to go based on their reputation. The only thing I need to figure out is how to pickup the BT signal,
I’ve found all Aranet devices connect quite well (to my Raspberry Pi) as long as they’re within a room or two. Anything further than this, and I guess something will be needed to extend the range.
However, as long as they’re within range, I’ve found that they stay connected with very few dropouts.
If you are looking for an all-in-one air quality monitor that includes radon, the Airthings View Plus might be worth looking into. You can find my full review here:
I’m still working on reviews for the EcoQube and RadonEye, as the apps seem unavailable in any of the App Store regions I can use (NZ, Vietnam, and the Philippines). I may need to purchase an Android phone and set the region to the U.S. before I can complete my reviews of these devices. However, this is important to remember if you live outside the U.S. (and maybe Canada), as I do. Make sure to check to see if you can actually use these devices before purchasing them.
I also have an Air-Q Basic review upcoming. While it doesn’t feature a radon sensor, it should show how the Air-Q Radon performs with the other metrics it monitors.
It looks like I’ll need to update this review soon! Airthings has announced the Corentium Home 2.
Airthings has now released the Corentium Home 2. Assuming this uses the same sensor/technology as the original Corentium Home (and therefore, has similar accuracy and performance), this looks like a device that improves on many of the flaws and limitations of the original:
Nice review! I picked up my radon detector last month, too - went with the Forensics Detectors FD-65-RADON after doing some research. Been running it in my basement here and it’s been working well so far. The 20-year sensor life was a big selling point for me since I don’t want to deal with constant replacements. Would be curious to see how it compares to those other models you’re testing when you get around to reviewing them. Good stuff, looking forward to seeing your full reviews!
The Aranet Radon Plus has now been tested by the C-NRPP (Canadian National Radon Proficiency Program) and it performed well. I think this may well be my most recommended radon monitor now as it has by far the best usability (but I haven’t tried the new Corentium Home yet) and comparable accuracy.
I have high hopes for the Corentium Home 2, but I can’t say for sure until I try it. However, compared to the Ecosense devices, the Aranet device has a much better app. The Airthings View Plus has a good app, but it’s significantly less accurate and the original Corentium Home has no connectivity at all.
You can read the full report here:
If you’re interested in this device, you can save 5% with the code: BREATHESAFEARANET (this is an affiliate link).
I’ve recently been working on a tool that allows users to compare radon monitors to pick the best suited for their needs. If you’re interested, you can find the tool here:
Pick a well-reviewed radon monitor and run it for at least 30 days to get a reliable long-term reading.
