I’m looking for a go-to mask to protect myself from COVID, as well as from other airborne pathogens, pollen, and air pollution.
Based on Aaron Collins’ list and video review, I’ve chosen SaveWo 3D Ultra Mask - it has a very good filtration efficiency and high breathability (low pressure drop), but as in the case of every disposable mask, storage and proper fit with multiple uses are the issue.
This made me inclined to look for an elastomeric half-mask/quarter-mask respirator. I have a GVS Elipse P100, but I can’t use it due to the strong plastic smell and high breathing resistance (I’m very sensitive to both).
What would be then the best elastomeric half-mask/quarter-mask respirator (with replaceable filters) for me? Maximum breathability (minimum pressure drop, especially important during exertion) and no plastic smell are my core priorities. High filtration efficiency and general ergonomics, obviously, matter a lot.
Hi @Biosecured! Thanks for joining the forum. Great question!
Yes, I agree. I also don’t like the Elipse as I find it quite sharp in some areas. When I first tried it, I was a fan, but after using it for a few extended periods, it quickly became probably my least favourite elastomeric due to how uncomfortable it became.
This is a tough question to answer, and obviously, it comes with the usual caveats (respirators are only effective if correctly fitted, my face will be different to yours, etc.). Still, I will do my best to provide some suggestions.
Firstly, I would ask if you only want this respirator for the abovementioned cases (COVID-19, pathogens, pollen, air pollution). I ask because if only these were available, we could look solely at half-face respirators with particulate filters; however, if it’s also something you might want to use around the house (for example, when painting), it’s worth looking at a half-face respirator with a range of filters. Furthermore, if you’re sensitive to plastic smells, I guess you might also be sensitive to other smells and want a nuisance odour filter.
I found the Dentec Comfort Air series to be the best regarding breathability. Other respirators also provide better breathability than the Elipse (like the 3M 6000 series, MSA Advantage, and some Honeywell respirators), but the Dentec beats all of these in my experience. It’s been a few years since I got my Dentec Comfort Air, so I can’t entirely remember the smell when it was new, but I seem to remember the 3M 6000 respirators as the worst in this regard. Unfortunately, even after a few years, they all still have a slight plastic smell, and I have to wonder if there is even a half-face respirator without such a smell.
Do you mind the quite large size and look of respirators like this?
Protection against pathogens (especially COVID), air pollution, and (to a smaller extent) pollen would be the primary use case, so if the sole focus on half-face respirators with particulate filters means substantially improved breathability (and minimum plastic smell from the mask), then I would certainly go for it. Bulkiness would be a minus - the less “controversial” look the mask has, the better, but I could make compromises here if they granted extra breathability.
Would it be possible for you to compare the filtration rate and breathability/pressure drop of:
Dentec Comfort Air,
ElastoMask Pro,
SaveWo 3D Ultra (subjective breathability similar to that of a surgical mask, reference list here)?
This would give me a great reference point. Using numbers would be great, even if these were just best guesstimates. Thanks!
Awesome, that makes this a bit easier! However, I think the bulkiness aspect might be a bit more challenging. If you don’t mind ‘only’ an N95, I would recommend checking out these respirators:
ElastoMaskPro - this is outstanding in breathability and isn’t so bulky compared to other half-face respirators. You’ve already mentioned it, so I assume you’ve already looked into this respirator, but if not, you can find my full review below:
Envo Mask - I have never tried their half-face option, but I did like their quarter-face respirator. The biggest issue is the seal, which I’ve heard is a bit fragile.
These options are smaller than most other half-face respirators and offer good breathability. I really like the ElastoMaskPro!
Unfortunately, I haven’t actually used the SaveWo mask, and I don’t know the exact breathability (in terms of numbers) of the Dentec Comfort Air. What I can say, however, is that based on Aaron’s results, the ElastoMaskPro and Savewo 3D have almost the exact same pressure drop (breathability), and I find the ElastoMaskPro to be incredibly breathable. The Dentec Comfort Air is a step behind these two, but that’s with P100 filters (Dentec also offers ‘breathable’ N95 cartridges, but I haven’t used these). I would say that the N95 cartridges are probably much better than other half-face respirators, but they are a step behind the ElastoMaskPro.
Honestly, if you don’t mind that it’s ‘only’ N95 (although, in reality, most N95s filter far more than 95% of particles), I think the ElastoMaskPro best fits your criteria. It’s relatively low profile and has exceptional breathability. EnvoMask could also be worth checking out, as that might also fit your criteria. Their site is currently down for maintenance, however, and I can’t see the exact details of their respirator.
Thank you! ElastoMaskPro seems like the best choice; it’s probably better to have a consistent ~8x COVID risk reduction with N95 than a recurring discomfort with P100, even though the latter is said to reduce the COVID risk ~20x times.
Five more questions, and I (and other likely-minded readers) should know everything at this stage :
Does ElastoMaskPro have a non-negligible (plastic) smell - and if so, does it go away with time?
Does ElastoMaskPro seem like the best available choice for a mask for exercise (indoor gym, jogging on a day with high air pollution)? I guess that more strenuous exercise should be avoided at all when having to wear a mask…
How would EnvoMask compare to ElastoMaskPro in terms of breathability, no/minimum smell, and general convenience?
If I had to/wanted to switch to the maximally breathable and minimum/no-smell P100, would Dentec Comfort Air be the best option?
How would you store respirator and disposable masks (lasting e.g. 20 hours) between uses? I’ve been assuming that most of the infectious pathogens are being trapped in the middle layer of the filters rather than e.g. on the surface of the mask, but I’d like to minimize the surface transmission risk as well, and I don’t have a UV lamp (yet) for the quick surface disinfection. Would a paper bag with marked sides (outer/inner side of the mask) be sufficient for storage between the uses, or do you have a better alternative in mind?
I agree, and that’s assuming the worst possible performance of the filters in the ElastoMaskPro. Aaron’s results show a > 99% reduction in particles, but this will depend largely on fit. The filters themselves, however, are capable of > 95% filtration.
It is better than most other elastomerics I’ve tried, and the smell does largely wear off over time. I’ve had a couple for around two years, and the plastic smell is faint. With that said, it is still noticeable, and I believe it will always be.
I would say so due to its fantastic breathability. Remember that this respirator has a similar pressure drop to the SaveWo masks! That said, I don’t think any half-face respirator is particularly comfortable once you start to sweat. I find the ElastoMaskPro a bit better than other half-face respirators in this regard, as the respirator material is softer and generally feels more comfortable on my skin. Still, it’s only comfortable as far as half-face respirators can be (when exercising, at least). If you are doing heavy or strenuous exercise, I would probably still recommend having some FFRs on hand.
I’ve only used the smaller Envo Mask, so I will refer to Aaron’s results here. From the look of it, the Envo Mask Pro has about 50% worse breathability than the ElastoMaskPro. This isn’t bad by any means, but it will be noticeable. Interestingly, both the N95 and N99 variants seem to have similar pressure drops (perhaps because of the exhalation valve on the N99 filters). From experience, the Envo Mask also has less of a smell (but this might be different on the larger respirator). I would say the ElastoMaskPro is the better N95 based on your preferences, but the Envo Mask Pro could be a ‘halfway’ between the comfort of the ElastoMaskPro and the protection of the larger, P100 half-face respirators.
However, if you are considering the Envo Mask Pro, I would recommend checking some recent reviews first. The gel seal used to be a weak point and wasn’t particularly durable. I’m not sure if they ever updated this or not.
From my experience, yes.
I would guess (and I could be wrong with this; I need to research it more) that most infectious particles would either end up on the surface or very early into the filtering layers. For example, viral particles are rarely ‘naked’ and are usually attached to larger, exhaled droplets or aerosols expelled during breathing, talking, coughing, or sneezing. These droplets range in size, but most are large enough to be captured in the outer or middle layers of a filter rather than penetrating deeply into the finer layers.
With this said, I tend to use marked zip-locked bags myself, which is very similar to what you currently do. I don’t think it’s ideal, but when out and about it, it’s probably one of the best ways to manage respirators!
On a side note: whatever respirator you do end up getting, I would recommend letting it air for a good while before using it. Unfortunately, all half-face respirators have noticeable smells, and it’s very hard to tell exactly what smell will be too strong. From my experience, those that I’ve recommended have less obvious smells, but they are definitely still present. Therefore, I would recommend airing them out and not wearing them for the first week or two if possible.
Thank you very much, Ethan, for such extensive answers! You’re doing excellent work - may it benefit many readers.
I’m also awaiting a reply from OmniMask re: the breathability and the plastic smell, as I would like to compare them to that of ElastoMaskPro, but I think I will go with the latter anyway. Hopefully, companies producing elastomerics will account more for both factors, especially given the rising general concern about microplastics.
Re: ElastoMaskPro, there are concerns about the accumulation of humidity and biomaterial due to the lack of a valved airflow. I’ve been told that because of this, the breathing resistance in masks lacking the exhale valve can drastically increase after just a few hours of use, and it isn’t usually indicated in the measurements/comparisons.
Re: OmniMask, I have learned about an independently measured pressure drop as small as 10 H20 with OmniMask using the 3M 2291 P100 filters (adapters required), increasing to just 12 after some use. I think that would make it the best possible choice on the market, with the only disadvantage being the cyberpunk look.
Sorry about the late reply! I didn’t see this response for some reason.
This is valid, but I also don’t know how much of an impact this would make. For example, even with one of the two filters completely covered, I still find the EMP to be a very breathable respirator. The respirator is exceptionally breathable, so even if breathability is halved, it’s still much better than most other half-face respirators.
That is an impressive breathability stat and almost as impressive as ElastoMaskPro’s 4mmH2O. Honestly, at this point, they’re both so breathable that I’m unsure how noticeable a difference even is.
However, I would be cautious about using adapters. I’m sure some people have conducted fit tests with this respirator, but I’m always cautious about using adapters and filters not originally intended for it - even if the adapters are made by OmniMask themselves.
I think either respirator would probably suit you well, and I think the biggest factor to consider is if you mind the look of the larger half-face respirators like OmniMask.
How is the ElastoMaskPro in terms of speech intelligibility?
I feel really intrigued by pretty much everything else about the mask, but am just concerned it might be difficult for other people to understand me when talking with it on. From footage I’ve seen of someone talking with it on, it definitely seems like it interferes to some degree, but I wanted to see what your experience is with it.
Good question! It definitely muffles my voice a bit when I wear it, but I honestly think it causes less muffling than most other half-masks. It’s very hard to objectively state which respirators make me more challenging to hear (and understand), but I think that this is better than most cartridge half-masks and slightly worse than a mask like Flo Mask and maybe the quarter-face Envo Mask.
Please let me know if you have any other questions!
Hello Ethan, have you made any updates with regard to the leading mask recommendations as of July 2025 (ranked by: filtration rate * low pressure drop * overall ergonomics * discreet look * absence of plastic smell)? My current top picks:
Large P100 respirator: OmniMask
Large N95 respirator: ElastoMask Pro
Small N95 respirator: Flo Mask Pro with Everyday Filter and condensation insert (I have both OmniMask and ElastoMask Pro, but I’m still considering the purchase of Flo Mask Pro, as the former are a bit bulky, and some people tend to react… aggressively)
Disposable N95: 3M Aura 9205+ (preferring respirators due to the consistent tight seal)
Some alternatives suggested by AI include Envo Mask, Breathe99 B2, O2 Curve 1.2, AirHead Mask, Totobobo mask, and R-Pur Nano Light.
Generally speaking, I think my overall picks are the same. I feel like mask/respirator world has slowed down a bit now, so there are less new entrants to the market.
Did you get a chance to try the OmniMask? I would be curious to hear your experiences with it if you have. I think it looks quite promising, my one bother with it is that it still looks quite ‘eye-catching’. With that said, I think that’s unavoidable in this class of respirators unless you go for something like the Elipse or StealthMask which aren’t ideal for reasons we discussed previously.
I should’ve read your comment through before replying - this answers my question! How do you find the OmniMask? In particular, how does it compare to the ElastoMask Pro?
I would also add the VFlex to this list. Some people love it, and some people don’t like it so much. However, I think it’s worth purchasing a few to test if you haven’t yet. Personally, I still prefer the Aura, but my wife vastly prefers the VFlex. Depending on where you live, I would recommend trying the Gen 3 Auras as well, as they’re fantastic respirators that improve on models like the 9205+ in almost every way. However, they can be elusive outside of Europe.
Based on everything you’ve said, I think either the Envo Mask or Flo Mask would suit you better. Both of them are certified to respirator standards (in Flo Mask’s case, it depends on which filters you use) and they’re more ‘serious’ than the others you listed. For example, most of the other models you mentioned are harder to fit (in some cases, almost impossible to fit without leaks) and I think they’re not quite as solid as Envo Mask and Flo Mask.
Since you are looking for an everyday mask that doesn’t attract ‘aggressive’ looks, I think the Flo Mask might be the better bet. It’s generally lower profile, and I’ve found that it attracts far less attention than Envo Mask. With that said, both are probably better than Omni and Elasto in this respect!
I have tried OmniMask with its original E100 filters, and the overall breathing comfort is high (or very high). With the exception of attention-drawing bulkiness, it is a complete package - high filtration, likely a low pressure drop (feels like in the ElastoMask Pro range), a triple valve system ensuring high breathability and low moisture buildup, good seal, convenient straps (though I tend to prefer good earloops), transparent mold, and minimum/disappearing plastic smell. Its compact version would easily become a #1 choice for all contexts.
I’ve been recommended Auras as an upgrade from SaveWo 3D Ultra (near-top choice in their category, but criticized for fit/seal issues after multiple uses). SaveWo seems to make interesting progress, though: 3DMASK EXTREME PRO RESPIRATOR (FFP3)|SAVEWO
Overall, I keep some disposable masks to share with others/as a backup, but lean towards the mold respirators with replaceable filters - a solid seal is half of the success.
Indeed, the current best bet seems to be Flo Mask Pro. Everyday Filters are way more breathable, and filtration-wise, (almost) as good during low-to-mid physical activity as Pro Filters (98-99% vs 99%), as the 95% vs 99% difference shows up with major exertion. Everyday Filters are unfortunately not available in the EU store, and the extra US shipping fees are too costly. Well, I’ll figure it out.
Just two more questions:
Any permanent plastic smell with Flo Mask Pro?
Many COVID-conscious people seem to adore Zimi masks. Have you ever tried them? Would any of their models (there are plenty of them, so it’s a bit confusing) be worth checking out? I’d probably choose one with a frame + earloops. Prioritizing minimum pressure drop with 95%+ filtration.
Thanks for sharing your thoughts! This is very promising to hear, and I might consider purchasing one for review - it’s been a while since I’ve come across a new but promising respirator or mask.
Not in my case. Mine is a few years old now, but assuming they haven’t changed anything regarding the materials used, the plastic smell wore off after a few weeks of use. While it was initially present, it was never as bad as with other masks, such as ElastoMaskPro.
Since it sounds like you are in Europe, I would recommend the Gen 3 Auras. They’re some of the best disposable respirators I’ve ever tried, and it’s one of the rare instances when respirators from outside the U.S. surpass those available domestically. I live in Asia, and I usually purchase Gen 3s from EU sites as they’re that good.
I think they’re definitely worth a try! I tried the ZM100 and one of the other models with a frame (also a KN100, but I can’t remember the model number), and I thought both were very good. To be honest, the main reason I don’t wear them more often is that they’re harder to obtain (and pricier, once you factor in the shipping) compared to the Aura.
I am unsure about their other products, but those with the frame and seal are worth trying - I would say they are contenders for some of the better respirators out there.
As of mid-November 2025, are there any new elastomeric respirators that are, in your opinion, worth checking out? When it comes to the composite score:
Filtration x Breathability (low pressure drop) x Internal comfort (moisture reduction, valves) x External comfort (comfortable and tight seal) x Discreet looks
Flo Mask Pro with Everyday Filters remains my #1. That being said, the fit is imperfect, and because it’s a quarter-respirator, its lower part rests close to my lower lip, making it difficult to talk or smile (and maintain a stable seal).
I’ve been thinking about trying Envo Pro N95 or Envo Pro N99 - their inhalation resistance is, according to tests, 9.1-9.7 and 9.9-10.2 mm H2O (NIOSH). Does it make sense to assume that, given that Envo Mask 95 had a 1.8x inhalation-to-exhalation ratio, we should expect ~17 and ~18-19 mm H2O inhalation resistance for Pro N95 and Pro N99? It’s probably ~3x as much as Flo Mask Pro with EFs, yet some people report more comfort with the Pro Envo masks. Thoughts?
It’s great to hear from you and thanks for the update. It’s always good to hear about your experiences! Sorry for the late reply on my side.
I think there’s been relatively little change or innovation since we last talked. As far as I’m aware, there aren’t any new promising respirators that are worth checking out.
That said, I’ve been looking to get a Breathe99 respirator for testing. I had a feeling that they wouldn’t be around for too long, but since Armbrust is selling them I am hoping they will be around for a while to come. Based on the testing I’ve seen, they’re capable of passing fit tests on some people with > 95% filtration (potentially higher if they have a good fit). They also fulfill the ‘subtle’ requirement perfectly - something which I am becoming a bit more conscious of. According to this report, the breathability is decent too.
I know we discussed these very briefly before, but did you ever try one?
Also, just this week I went ahead and ordered both some Zimi and Laianzhi masks. I am looking forward to trying both because they both have very good reviews online. I’m not sure how long the shipping time will take with holiday season upon us, but I should be able to provide a better update in January!
Thank you very much, @Ethan! Greatly appreciating your clean air efforts, looking forward to the upcoming tests.
In terms of elastomeric respirators, I’ve tried what seems to emerge as the Top 3 of elastomeric respirators: Flo Mask Pro, OmniMask, and ElastoMask Pro. I’m curious about Breathe99, Zimi, and Envo Pro N95/N99. Do you have any experience regarding the Envo Pro models, or plan to test them?
As for the further search, back-and-forths with AI suggest a rather low chance for overlooking any hidden gems beyond what we’ve already discussed, but they occasionally add one or two more previously unmentioned recommendations - one recent was Forged Air half mask, emphasizing low pressure drop and high speech clarity: Testing – ForgedAir
You’re welcome! I am also looking to get some Drager masks (the X-plore series looks to be very popular) but they’re both incredibly hard to source and insanely expensive here. I hope to be able to test them soon, however.
I still haven’t been able to try the Envo Mask Pro because as soon as I ship one here it comes out to significantly over $100. However, I am quite happy with the original Envo Mask as my face is quite small so I continue to use that. I will be able to share my experiences with Zimi soon!
I actually remember ForgedAir from a few years ago, but I hadn’t heard of them for a while and forgot about them. It looks like they’re in the process of getting CSA and NIOSH approval. If they can get either (or both) I think this could potentially be a great choice.
As per this image, the ZM7711 is supposed to be small, but even I have to tighten it a lot to get what feels like a good fit (I do have a very small face - or so I’ve been told). They also seem to be a bit large for my wife, so we’ll likely get XS next time if it’s available.
With that said, when the Zimi is tightened, I can pass a qualitative fit test and it feels very comfortable minus the pain on my ears. I think I will re-order some with the head strap for myself.
I wasn’t expecting too much from the Laianzhi masks as they looked to me to be more or less a standard (albeit high quality) tri-fold. However, the T99+ has really impressed me. While I need some more time with the respirator, I think this may well be one of my favourites. It fits me very well, and it’s comfortable to wear. Out of the box, it feels like it fits me as well as an Aura which I am quite surprised about.
It’s very hot here at the moment (about 35 Celsius everyday) so I will let you know how I hold up with these outside!
