Hi all. I’m looking to get some help with a tricky problem of mine. I have Ideopathic Environmental Intolerance (IEI), aka Multiple Chemical Sensitivities (MCS), which means I experience physiological reactions to VOCs and other substances commonly found in things such as cleaning products, air fresheners, perfumes, certain plastics - anything that “off-gasses”. I even have reactions to some masks (such as the 3M Aura, sadly), due to the materials used in manufacturing them. This syndrome greatly affects my life and my ability to work.
The substances that trigger my symptoms are not usually blocked by N95 or KN95 respirators. Sometimes such respirators help, but sometimes not, I don’t really get why - maybe it has to do with the particle size of the substance causing the reaction, I don’t know. Such substances are also not removed by HEPA or MERV filters. Charcoal filters, and filters including minerals like titanium dioxide, zeolite, and zinc oxide seem to help, but these aren’t found in respirators.
To my knowledge, the only type of masks that would block these things are the kinds used by professionals - P100 and the like. However these masks are not practical for everyday use.
Can anyone recommend a consumer level mask that will help block such substances/gases/VOCs? I think a lot of air fresheners are oils, though I don’t know for sure. Air fresheners, perfumes, and cleaning products seem to be the main culprits. Even something that blocks some of this stuff would be helpful.
I struggle badly with air fresheners etc too so i found these LUPA FFP3 NR D Active Carbon Mask | The Face Mask Store - i don’t know if they actually work as they don’t fit my face comfortably but worth a try. I am told that the quantity of carbon is important for blocking things so I don’t know if they have enough carbon in them to provide protection for long. I also use an air purifier with a carbon filter layer, which helps.
Unfortunately, for the best protection, you will need a half-face respirator with organic gas/vapour cartridges. Most large half-face respirator manufacturers offer these cartridges in some of their respirators (3M, Honeywell, Moldex, etc.). However, as you mentioned, they aren’t ideal for daily wear, and it looks like they emit VOCs themselves (VOC emissions from particle filtering half masks – methods, risks and need for further action - PMC)!
However, if we are talking about nuisance levels, there are a few other options that might work for you. To add to @HarryLeWhippet’s suggestion, I would also recommend looking into these:
Regarding keywords to search for, look for ‘nuisance’ odour/vapour respirators. These tend to be R95 or above, and they’re probably the best bet for your situation. I hope this helps!
Thank you so much to both of you for these amazing resources. I didn’t know about masks for “nuisance vapors” or that masks with charcoal existed - I think these would provide some protection at least. Anything is better than nothing!! @Ethan, I’m really grateful for your diligence, both with this particular topic and the site in general. It’s such a big help.
I forgot to add that I’m located in the US… I’m having trouble finding those 3M ones for some reason. But I’d consider ordering overseas for something that helped me with this pesky issue.
@HarryLeWhippet , that is a very useful article. Sobering indeed, but also quite heartening to me to read those statistics about people’s views on air fresheners. I had no idea it was so common for people to suffer reactions to them, or that so many people would consider not using them anymore if they knew how unhealthy they are. I’m optimistic that this situation will gradually improve, especially since indoor air quality is a growing concern worldwide. But for now it’s extremely vexing.
I know there is at least one brand of those tiny personal air purifiers (the HEPA ones, not ionizer ones) that has a charcoal filter… maybe it would be of some benefit worn around the neck? Not sure if those things work at all, though.
You’re welcome. I’m glad the answer was helpful! I did a brief search on Amazon (which I assume is the easiest for shipping) and came across a few masks/respirators with some form of carbon/nuisance odour filter.
It is worth noting that I haven’t tried any of these (other than the 3M 8246), and they’re all cup-style, so they likely won’t provide the best seal. However, fit is personal, and you’ll need to try them yourself to see if they work. I’m sure there are more too - I just searched ‘nuisance odour respirator’ on Amazon and got those as the top results (that are from trusted brands and NIOSH certified).
I’m not too sure on this. I’ve heard that some of the personal air purifiers are effective, but I have no idea about the carbon/charcoal filter aspect. @HarryLeWhippet actually created an interesting topic about one of these portable purifiers the other day.
Apologies for reviving this thread, but it’s getting quite a bit of traction, so I would like to add some updates for anyone else curious about this topic.
The best respirators for protection against odours and VOCs will always remain half-masks (half-face respirators) with either activated carbon or organic vapour cartridges. Quite a few half-face respirators have these types of filters, and you can find a list of some of them here:
It’s also possible to get PM + OV filters to protect against particulate matter and organic vapours. However, it’s important to check which respirators support which filter types (and how easily accessible they are) before investing in a brand.
Of course, many people don’t want to wear a half-face respirator in everyday situations and that is understandable. If you’re in this situation, I would recommend checking out some of the following respirators (please keep in mind the usual caveats, such as that fit testing is vital to ensure the best protection):
3M 8246 (R2/R95)
3M 8247 (R95)
3M 8577 (P95)
3M 9542 (P2)
3M 9913 (FFP1/P1)
Moldex 2400/2500 (N95 + carbon)
Moldex R95 (2840/2940) Series (R95)
Moldex 2800N95 (N95)
Honeywell SAF-T-FIT Plus (N95, N99, R95 and P100 variants available)
Dräger X-plore 1300 (Many variants, but only N95 has an odour-filtering option)
Dräger X-plore 1700 (FFP1, FFP2 and FFP3 variants available. Note: not all have a carbon filter. Make sure to look for a version with an activated carbon layer)
I’m sure there are many more out there, but these are some of the most popular options for nuisance odour respirators. However, please note that many of these have both nuisance-odour and normal variants, so you will want to be careful about what you purchase.
