Hi everyone!
Over the past few weeks, I’ve been working on a tool that can be used to compare air quality monitors. It’s taken a lot of work, but it’s finally online and useable.
This is something I’ve wanted to create for quite a while as it’s very difficult to directly compare air quality monitors - even I’ve run into this issue! This is the kind of tool I always dreamt of being able to use.
If you’d like to give it a try, you can find it at the link below!
You can browse the database and different categories from the homepage. To compare monitors, simply select 2-4 monitors (with the checkboxes indicated below) and press ‘compare’.
This will lead you to a screen like the following where you can directly compare the monitors:
Since uploading monitors is quite a manual process, I’ve only added some of my favourite carbon dioxide monitors so far. However, this will continue to expand over the next few weeks!
If there are any monitor requests, please let me know! I’ve also created a submission form so manufactures can add their own monitors if interested. Just leave me a comment or send me an email and I can provide this!
I’m sure there are still quite a few bugs and things that can be improved, so I welcome all feedback!
