MoreSense MS-07 temperature, humidity, particulate matter, co2, NOx and VOC sensor
  • MoreSense MS-07 will soon be available on Tindie
  • 3.5 inch IPS 480 x 320 capacitive touchscreen
  • ESP32 S3 MCU
  • Measures 9 air quality parameters
  • Clock
  • Powered by the new Sensirion SEN66 sensor
  • Built-in charts with 24-hour history, and over one year of data accessible via the web interface**
  • Unlimited measurement storage (CSV format) on microSD card
  • User-configurable alarm thresholds (orange & red) for each measurement parameter
  • User-configurable HTTP commands per parameter for threshold exceedance and recovery events (e.g., to control HVAC devices via WiFi smart plugs).
  • Integrates with Home Assistant, Domoticz, and many other home automation systems via MQTT or REST
  • Compatible with Homey through the HomeyDuino app
  • Comprehensive web interface
  • Panasonic 18650 Li-Ion 3000 mAh battery
  • Eco mode for extended battery life, with a user-configurable measurement interval. The sensor wakes up at each interval, takes measurements, and then returns to deep sleep.
  • User-selectable WAV files for alarm sounds
  • Price will be around $ 160.00
  • …and many more features
Hi @Lars,
Thanks for sharing! I have a few questions:
  1. You mentioned extended battery life - what is the estimated range of battery life (with the lowest measurement intervals vs the highest)?
  2. Do you know when this will go on sale?
  3. Can it be wall mounted? It looks like it would be the perfect device for this.
I think it’s quite an interesting device and look forward to hearing more.
Hi Ethan,
Thank you for your interest! I haven’t tested the battery life in eco mode yet, but each cycle consumes about 4 mAh. So theoretically, the 3000 mAh battery could last for around 750 cycles, which is about one month if it runs at one-hour intervals. But that is theory, I think it is more realistic to divide the time by two.
At the moment I am working on the user manual which will probably take about 2-3 weeks from now. So after that it will go on sale.
As you can see the sensor has wall mounts.
I also added some screenshots of the web interface so you can get an impression of all the options.
Please let me know if you have any further questions.
